AutoCAD LT
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: Block Editor Help
- Highlight
- Email to a Friend
Alright here is a start:
The Angle works fine.
The Attrib Distance is the length of the Arc drawn here. LT will not allow you to Stretch an Arc as I believe current Full CAD with Parametrics will so I cannot do more with the Arc. Since it is static it will not update the Field.
However - This would give you the Distance needed by being able to Stretch the Arc and deducting the Piece of Arc you started with.
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
- Highlight
- Email to a Friend
Very nice!
I am enquiring to autodesk about the cost to upgrade 2012 LT to full version. I miss the 3d capabilites so now would be a good time to get it done. The angle works beautifully. Thank you for your help!
- Highlight
- Email to a Friend
Just to let you know. There is no "upgrade price." I contacted autodesk and asked the same thing and was told there is no "cross-grade" right now. (why would there be?) Also the price for full is around $4,000-$4,500 depending on what you select for subscription.
Brandon Gingerich
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
I contacted Autodesk and they advised me they dont do cross upgrade from LT to full version. They advised me to refund my LT version and buy the full version. Seems like an extra 2grand.. I think I will just spend the time to use visibility settings to get this under control.
- Highlight
- Email to a Friend
You also need to post this block in the Dynamic Block Forum
Dynamic Block Forum:
http://forums.autodesk.com/t5/Dynamic-Blocks/bd-p/
Someone there with Full may pick it up and get the Arc to Stretch or see another solution.
If it is built in the Full version it can be used in LT generally.
- Highlight
- Email to a Friend
Thanks Charles!
Hopefully someone can get this on the right track. I appreciate your helpfulness!
- Highlight
- Email to a Friend
I was able to get this working using full version of AutoCAD. Constraints are valueable and I think I will be pushing my employer to purchase ASAP.
Thanks again for all the feedback and thanks Charles for your help as well.
- Highlight
- Email to a Friend
Post it I'd like to see.
You're welcome
- Highlight
- Email to a Friend
Here it is.. a few bugs to work out with the correct dimensions displaying but its working pretty nicely.
