• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    *Lyon, Steve
    Block Does Not Turn On/Off When I Turn It's Layer On/Off
    398 Views, 5 Replies
    11-20-2002 08:49 AM
    I import a block onto layer A
    I check it's properties to make sure it is on layer A and it is
    When I open Layer Properties Manager and turn Layer A off , the block does
    not disappear from the drawing
    When I turn Off Layer C using Layer Properties Manager, the block disappears
    I would appreciate any help!
    Steve Lyon
    Please use plain text.
    *Klasson, Conny
    Re: Block Does Not Turn On/Off When I Turn It's Layer On/Off
    11-20-2002 05:07 PM in reply to: *Lyon, Steve
    It's now when layer 0 comes in handy.
    Put your objects on layer 0 before you create the block.
    Now all objects inside the block will use the same layer
    properties as the layer where the block is inserted.
    Conny
    "Steve Lyon" skrev i meddelandet
    news:9B33209C890EA6F3337EF59BA620DF33@in.WebX.maYIadrTaRb...
    disappears
    > Thanks
    > Steve Lyon
    *Rudolph, Dietmar
    11-20-2002 05:08 PM in reply to: *Lyon, Steve
    Steve,
    the lines in your block have been drawn on layer C. Thus they get
    turned off when layer C gets turned off. Your block could have had
    many lines on *different* layers and each part of the block would
    react to their layer visibility. To turn off a block with all lines
    disappearing, you need to FREEZE the insertion layer, not turn it OFF.
    Dietmar Rudolph
    President, CR/LF GmbH, http://www.crlf.de
    Vice-President Europe, CADLock, Inc. http://www.cadlock.com
    Member of the Autodesk Discussion Forum Moderator Program
    Author, "Mastering AutoCAD 2000 Objects", http://www.crlf.de/Verlag/PublishingServices.html
    *Rudolph, Dietmar
    Re:
    11-21-2002 04:46 PM in reply to: *Lyon, Steve
    Steve,
    please keep the discussions in this newsgroup, not in email!
    You are correct. Distributing the objects within a block on various
    layers makes sense for global linetype or color changes. It makes much
    more sense if the same block contains different 'images' to be
    displayed. Think of a block which stands for some machine. Now have it
    a schematic view drawn on layer X and a detailed view on layer Y. By
    selecting the correct layer, your complete drawing changes from
    schematic to detailed view or vice versa.
    Dietmar Rudolph
    *Lyon, Steve
    Re:
    11-23-2002 06:50 AM in reply to: *Lyon, Steve
    Dietmar:
    I apologize for the email. This is the fist time I have used a newsgroup and
    I must say I am very thankful for all the help!
    I guess the policies and procedures for the business that you are in are key
    to the approach you take. In what we have been doing, mechanical drawings,
    incorporating blocks that contain casters, bolts, etc.. we have been putting
    in centerlines, hidden lines, and in some cases dimensions. In defining the
    naming strategy of our layers the blocks can be imported and centerlines
    quickly hidden from view and plot. We sill have the option of loading a
    materials list on a completely different layer for display within the
    drawing as a hole or separately as required.
    Thanks so much!
    Steve
    "Dietmar Rudolph" wrote in message
    news:thrrtus1oem1fnsomitc3aj20a7itvvfps@4ax.com..
    > Steve,
    > Dietmar Rudolph
    *Norris, Ric
    12-13-2003 09:57 PM in reply to: *Lyon, Steve
    Sounds to me you have more than 1 Layer (C) in your block. Not a real good
    idea. You need to explode it.
    Ric Norris.
    http://users.bigpond.net.au/cavedrawings
    "Steve Lyon" wrote in message
    disappears
    > Thanks
    > Steve Lyon
