• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Re: Big problem in AutoCad2012
    04-25-2012 06:38 AM in reply to: Charles_Shade
    Can you sent to me your mail ?to sent two error massege.
    Please use plain text.
    04-25-2012 06:51 AM in reply to: AmrMagdy
    Can you give Your Email ? to sent two error massege when i open
    because it more size
    *Expert Elite*
    Charles_Shade
    04-25-2012 07:01 AM in reply to: AmrMagdy
    Private message at the top of the Forum page will be where to request that.
    Not sure if you can post a larger file.
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    04-25-2012 07:36 AM in reply to: AmrMagdy
    this error when i open
    04-25-2012 07:39 AM in reply to: AmrMagdy
    sorry
    the password is 111
    *Expert Elite*
    Charles_Shade
    04-25-2012 07:51 AM in reply to: AmrMagdy
    My Windows XP does not recognize the Compression method that you are using so I am unable to open your Drawing file or Bitmap.
    Try purging the file or saving the Bitmap down to something smaller to see if you can post those.
    You may want to try RECOVER on the drawing file to see if that cleans it up for you.
    Or type XREF from the Command line os Dean suggested and see what may or may not be there.
    Detach the XREF's if thet are there to make the Drawing file smaller.
    *Expert Elite*
    pendean
    04-26-2012 05:37 AM in reply to: AmrMagdy
    Save your screenshot as a PNG or JPB, not the oversized BMP, then you can post it without compression.
    I take it you are using a MAC and forgot to mention it?
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    04-28-2012 12:01 AM in reply to: pendean
    this is the error that ocurred when i open drawing
    *Expert Elite*
    pendean
    04-29-2012 09:14 AM in reply to: AmrMagdy
    In LT, turn on PROXYSHOW and PROXYGRAPHICS variables, and turn off PROXYNOTICE variable (look them all up in HELP): those are not "problems", that's an informational message letting you know your file contains objects not designed for use with LT.
    Ask the file creator to "EXPORT TO AUTOCAD" those files for you then ask them to resend the DWG files to you, or you can try to do the same (after you do all the above I mentioned) with -EXPORTTOAUTOCAD command (note there is a dash in the name of the command). This does not always work since you did not create those objects in LT.
    New Member
    04-29-2012 11:58 PM in reply to: AmrMagdy
    All of these tips are very important for creating eye-catching content but the call to action tip really stands out because everyone can do more of that and often it gets overlooked. Also bringing valuable information will go far too and will help that readers will not only stay on your page, but come back. Great post !!
