AutoCAD LT
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Autocad repeat command?
- Highlight
- Email to a Friend
HI, Sorry to ask dimwit question and I tried to find the answer but....
Isnt there a setting/preference that has to do with repeatng the previous command without having to hit the command or reentering the command ? I know not all commands have it but I recall some do. Isnt there a setting to control that?
Thanks!
Re: Autocad repeat command?
- Highlight
- Email to a Friend
Just hit Return
- Highlight
- Email to a Friend
You can also press the space bar. You can also use the MULTIPLE command. You can also add a * before your macro for example *^C^CLINE;
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
Thanks for the feedback!
I found a new one for me, anyways.
Went to Tools>options>user prefernces>"right click customization">.....then ther some options for using the and setting the function of the right mouse click..maybe thats what Ive been looking for.
Thanks all for the responses!
- Highlight
- Email to a Friend
...you can even set that mouse to a time-sensitive click, to give more than one possible option of what that right-click does!
- Highlight
- Email to a Friend
If you only turned off right-clicking, you just removed about a third of the LT program from access by you to get things done.
A big mistake you will wish you had not later.
Turn on time-sensitive right-click instead as I noted and as noted in the reply above this one.
- Highlight
- Email to a Friend
No I didint turn off the right clicker.
I went to :
Tools >options> user preferences>RIght Click Customization> >then under Default Mode I changed it to "if no objects are selected , right click means," "REPEAT LAST COMMAND" (instead of "short cut menu")
Havent used it this way much yet but am going to try it.
Thanks again.!
