• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Active Contributor
    Autocad repeat command?
    1202 Views, 7 Replies
    11-22-2011 08:26 AM
    HI, Sorry to ask dimwit question and I tried to find the answer but....
    Isnt there a setting/preference  that has to do with repeatng the previous command without having to hit the command or reentering the command ? I know not all commands have it but I recall some do. Isnt there a setting to control that?
    Thanks!
    Please use plain text.
    hwalker
    Re: Autocad repeat command?
    11-22-2011 08:46 AM in reply to: jakeslicks
    Just hit Return
    11-22-2011 08:58 AM in reply to: jakeslicks
    You can also press the space bar. You can also use the MULTIPLE command. You can also add a * before your macro for example *^C^CLINE;
    pendean
    11-22-2011 08:58 AM in reply to: hwalker
    or right-click and select "repeat" listed at the top (especially useful too if you actually launched a menu macro and not just a single command).
    or turn on fast right-clicking in OPTIONS and simply "fast right-click" to repeat the last command.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    Active Contributor
    11-22-2011 09:33 AM in reply to: Johneng
    Thanks for the feedback!
    I found a new one for me, anyways.
    Went to Tools>options>user prefernces>"right click customization">.....then ther some options for using the and setting the function of the right mouse click..maybe thats what Ive been looking for.
    Thanks all for the responses!
    Bob_Zurunkle
    11-22-2011 09:43 AM in reply to: jakeslicks
    ...you can even set that mouse to a time-sensitive click, to give more than one possible option of what that right-click does!
    If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
    pendean
    11-22-2011 10:49 AM in reply to: jakeslicks
    If you only turned off right-clicking, you just removed about a third of the LT program from access by you to get things done.
    A big mistake you will wish you had not later.
    Turn on time-sensitive right-click instead as I noted and as noted in the reply above this one.
    Active Contributor
    11-22-2011 12:30 PM in reply to: pendean
    No I didint turn off the right clicker.
    I went to :
    Tools >options> user preferences>RIght Click Customization> >then under Default Mode I changed  it to     "if no objects are selected , right click means,"       "REPEAT LAST COMMAND" (instead of "short cut menu")
    Havent used it this way much yet but am going to try it.
    Thanks again.!
