AutoCAD LT
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Autocad LT 2012 installati on error failed to load ADLMPIT.DL L
- Highlight
- Email to a Friend
I am trying to install an Autocad LT 2012 on a MS Windows Vista Home Premium SP2 but i can get to the initialization stage. Everytime I try to install it I would encounter the same issue over and over again. The error is all about the ADLMPIT.DLL. It says it failed to load. I have already installed the MS .NET Framework 4.0 and disabled my antivirus but it didnt do any difference at all. Can you help me with this issue.
Re: Autocad LT 2012 installati on error failed to load ADLMPIT.DL L
- Highlight
- Email to a Friend
Uninstall the .NET framework.
Follow this advice from Autodesk:
Remove Autodesk Products:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?li
Now try the install.
You may also want to post in the Installation forum:
Installation and Licensing Forum:
http://forums.autodesk.com/t5/Installation-Licensi
Google search the *.dll as well and you may get a Forum or other hit concerning that.
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
- Highlight
- Email to a Friend
I have the same problem, how to resolve ??
- Highlight
- Email to a Friend
What of the above advice have you tried?
- Highlight
- Email to a Friend
I've tried con advice above but did not work
- Highlight
- Email to a Friend
If it is a .NET issue then you may need to do more to the .NET install. This is a link to a thread that concerns the .NET issues. It's origin is a little older but the remedy is sound. If you find it not working for you or otherwise have issues ping Travis and he will be happy to help.
.NET Cleanup Utility:
Also search the Installation and Licensing Forum:
for this issue.
