• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Active Member
    Autocad 2011 LT opens a file then close
    310 Views, 6 Replies
    12-04-2012 02:31 AM
    Hello, I have an issue with my computer.
    Whenever I open a file, it stats loading it, the file appear (ligns etc etc), but then it simply closes.
    The program however stays open.
    It doesn't do it with all the files I have, mainly the one which have objects created with Archicad.
    I am the only one at the office have those issues with those files.
    What can I do?
    Please use plain text.
    bgingerich
    Re: Autocad 2011 LT opens a file then close
    12-04-2012 04:34 AM in reply to: ryan.smyth12
    How are you opening the file?  Windows Explorer or through the OPEN command?
    Does it work to open the files with the RECOVER command?
    Other users can open those files no problem?  What is different on your workstation?
    (if ("mysolution"=answer) then (click "Accept As Solution"))
    Brandon Gingerich
    Active Member
    12-04-2012 04:38 AM in reply to: bgingerich
    Ok, so opening via windows or the open command had the same happening.
    But I tried via recovering the file, and tada, it worked. Thanks.
    bgingerich
    12-04-2012 04:43 AM in reply to: ryan.smyth12
    Glad I could help!
    Brandon Gingerich
    Active Member
    03-15-2013 09:48 AM in reply to: ryan.smyth12
    Hello there, I have the same problem, and I am getting a little bit tired of recovering the same file every time I want to open it.
    What should I do? save-as something else?
    Active Member
    03-22-2013 06:35 AM in reply to: ryan.smyth12
    Hello again.
    As I didn't get any answers, I tried copying everything onto a new file.
    The problems stayed.
    When I recovere the file, it find 36 errors, which it says to be resolved.
    What can I do?
    Charles_Shade
    03-22-2013 09:30 AM in reply to: ryan.smyth12
    Use WBLOCK instead of Copy/Paste.
    Then run the AUDIT or open with Recover from the Big Red A drawing utilities menu.
    Does that help the file?
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
