• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Member
    AutoCad 2012LT problem with Esc button
    598 Views, 8 Replies
    09-28-2012 06:05 AM
    Hi;
    I have a problem with using Esc button. I mean, cancel the command, deselecting of selected object. I have read a lot of discussions about it and I found that this problem occurred when Adobe Photoshop  is running with AutoCAD in same time . In my case, I do not have any installation of ADOBE products in my computer expect Adobe Flash player. Working with this BUG make me crazy, I always have to press right mouse button and choose from the menu Cancel or Deselect All.
    I also changed a settings in CUI menu (user interface) and I changed ESC button in shortcut for CANCEL to F1 button.
    http://lynn.blogs.com/lynn_allens_blog/2005/10/the_best_autoca.html
    Problem with cancel of command was fixed but deselecting of selected objects is still not working.
    Is here somebody who can help me ? Please.
    Thank you very much for tips and tricks
    Please use plain text.
    pendean
    Re: AutoCad 2012LT problem with Esc button
    09-28-2012 06:23 AM in reply to: matejtomka
    Do you need to hit ESC twice or more to deselect maybe?
    Do you just need to set PICKFIRST to 1 perhaps?
    Or do you need to click inside AutoCAD first before hitting the ESC button (bring it back into focus in Windows)?
    Or are you using a Wireless keyboard? a keyboard with a "driver"?
    Did the problem occur AFTER you changed the setting in CUI?
    Newer update to your old link BTW: http://www.youtube.com/watch?v=A4DAxAGYYv4
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Member
    09-28-2012 09:02 AM in reply to: pendean
    Thank you very much for feedback.
    The video from youtube: I have made this substitution Esc button for F1 button ... F1 is working only in case that I want cancel or finish command but it is still not working when I need deselect objects. I have to use right mouse button like I have explain before.
    Regarding keyboard: I have keyboard connected to PC using USB
    and believe me  can press Esc or F1 ( after substitution 1000 times and it is not working.
    matej
    pendean
    09-28-2012 11:02 AM in reply to: matejtomka
    Is LT2012 fully updated and patched?
    Does ESC work in any other application? It has the same function (cancels a command that is running or deselects objects of that function is part of a command or both), it's a Windows feature.
    I'm not able to replicate your issue (and I have Photoshop installed, Win7 Pro 64bit). Hopefully someone else has ideas to try, or I'll come back if anything jogs my memory.
    BTW, holding your mouse' right-click button down for more than a second also deselects objects: nothing to pick.
    Member
    10-01-2012 01:23 AM in reply to: matejtomka
    Hi again,
    regarding last tips: ESC button is ok and it is working without problems for another applications.
    I have made a small experiment and result is little bit surprising for me. In my job I use a lot,  software named CX Programmer.
    When this software is running the ESC function for AutoCAD LT (in my case 2012) is not working anymore.
    Is this problem with RAM ? or do anybody have some idea what is going on ?
    PS: this software is not a product of ADOBE family.
    Thank you for any feedback.
    After substitution or change a ESC button for F1 button canceling of the command is working but deselecting not.
    Holding a right mouse button is my only one chance how to work faster.
    Best regards
    MATTE
    Charles_Shade
    10-01-2012 05:03 AM in reply to: matejtomka
    Does the CX Programmer work within LT or separate?
    Regards, Charles Shade            Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
      Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    Member
    10-01-2012 05:15 AM in reply to: Charles_Shade
    the CX Programmer is working separately but if I start this program when AutoCAD is running problem with ESC button occurred. When I close application CX programmer problem with ESC in LT disappear and the button is working without problems. Problem is when this two applications are running in same time.
    BR
    Matej
    pendean
    10-01-2012 05:29 AM in reply to: matejtomka
    Software conficts: never heard of this other program, perhaps someone at Autodesk has. Typically it takes both companies to acknowledge there is a conflict and both work together to resolve it.
    That almost never happens fast enough for end users sadly. But at least you know how to control it.
    Contact the other firm and see if they know how their program "grabs" ESC button, perhaps they have a fix or workaround that does not involve shutting down the program.
    Member
    10-01-2012 05:42 AM in reply to: pendean
    I will do it !
    in this time I make an UP Date of CX Programer and if the problem with ESC will be here again i will contact the people from OMRON.
    Thank a lot for feedback
    Matej
