• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    New Member
    AutoCAD LT2013 Can this software run on windows 8
    1355 Views, 5 Replies
    11-20-2012 06:59 AM
    Please use plain text.
    Distinguished Contributor
    KateMorrical
    Re: AutoCAD LT2013 Can this software run on windows 8
    11-20-2012 07:05 AM in reply to: dalesteels
    DarrenP
    11-20-2012 07:51 AM in reply to: KateMorrical
    it can probably run but its not a supported OS for LT 2013
    pendean
    11-20-2012 08:30 AM in reply to: DarrenP
    Some folks are having a hard time just installing it, so "probably run" can be an expensive paperweight option.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Product Support
    11-22-2012 11:43 AM in reply to: dalesteels
    The short answer is no.  However, we will update this solution when it will be.
    http://usa.autodesk.com/getdoc/id=TS19048377
    This blog post also talks about it as well.
    http://upandready.typepad.com/up_and_ready/2012/11/windows-8-support.html
    The main issue is that Windows 8 is using a newer version of .NET (4.5) and we install .NET 4 with an Autodesk 2013 product.  The Media and Entertainment products are not using the .NET framework as much so the transition to newer operating systems is not affected by this requisite.
    David Lau
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
    My 5 Top Issues in the Discussion Groups
    1402 Error [Uninstall] | Faro doesn't install | adlmPITSetProductInformation Errors | Empty Tool bar in AutoCAD Mac | Win 7 Registry Limit
    Product Support
    11-22-2012 12:47 PM in reply to: david.lau
