AutoCAD LT
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
AutoCAD LT 2013 export/imp ort SHP files to GIS
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The company I work for is looking into buying new AutoCAD software due to upgrading computers. We don't use 3D commands at all and are looking into purchasing the LT version for budgeting reasons. What we are trying to find out now is if you can export and import SHP files from GIS ESRI software. Are you able to edit the SHP files if necessary? Any advice on this would be helpful.
Thanks in advance.
Re: AutoCAD LT 2013 export/imp ort SHP files to GIS
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
i don't believe you can bring in .stp files into autocad LT
since its LT your very limited on what file formats you can use
you need to look at full blown autocad or Autocad Map 3d
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm wondering about .shp file or shape files not the file extension for the 3D graphic file. We do not use any 3D files.
Thanks though.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
OK. Thank you very much. Is there any where that states this in some sort of print out. I need to have something to give to the supervisors, if you understand what I mean.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Download a Trial and see what you can and cannot do first hand.
You can Google relationships between AutoCAD Full and AutoCAD LT.
Map will not have a comparison matrix with LT but AutoCAD Map can be Trialed as well.
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You should be field testing software IMHO to find what works for you: the entire Autodesk line is available for download, you can rule out or decide on what you seek in less time that asking, finding documentation, sending up the river to spervisors, them asking more questions, you coming back for clarifications... and so on.
You know they aren't going to buy your first response, especially when the$$ discount is huge, right ![]()
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
A quick FYI - AutoCAD doesn't do GIS SHP work, but Map3D does. Any references to SHP files in AutoCAD refers to shape definitions for SHX fonts and shapes used in line type definitions. With object enablers you *may* be able to make do a couple of licenses of Map3D for the high-end content and the grunt work with LT.
Adopt. Adapt. Overcome. Or be overcome.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I guess I should rephrase then. I need to export the files to .shp files. We design our mapping system layouts and grids using AutoCAD .dwg files sent to us from builders and developers. We need to be able to export/import the files to our mapping system. It has to be a .shp file. I was wondering if the LT version had that option. From what I have found it does not. Correct?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
correct it does not have that option
look at Map 3D
