• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    New Member
    AutoCAD LT 2013 - Crashes at startup
    1515 Views, 3 Replies
    10-15-2012 02:53 PM
    AutoCAD LT 2013 - Crashes at startup and haven't been able to use at all!
    Autocad opens and them it closes itself very quick. It doesn´t give me any error. The program was running ok, until last week. Haven´t make any system changes
    I´ve tried to uninstall and them install de program, reinstall :NET framework and still nothing
    Please help
    Please use plain text.
    Charles_Shade
    Re: AutoCAD LT 2013 - Crashes at startup
    10-16-2012 05:01 AM in reply to: cemexni
    Since you have already tried a reinstall this may not work but s System Restore to a week or more ago may correct the error.
    Do you allow Windows to automatically update your system?
    Autodesk Recommended Clean Install Procedure:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
    More complete .NET fix if you did not go through this procedure:
    .NET Cleanup Utility:
    http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
    Regards, Charles Shade            Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
      Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    New Member
    10-16-2012 07:57 AM in reply to: Charles_Shade
    Hi Charles, thanks for the reply
    I removed all the autocad using the procedure you mention and using the cleanup utility for remove the .NET Framework, and still nothing.
    I´m afraid the system restore is not an option for me, because is turned off in the pc.
    Do you have any other ideas??
    Charles_Shade
    10-16-2012 09:05 AM in reply to: cemexni
    Another place to post for Installation Errors:
    Installation and Licensing Forum:
    http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
    If you are not receiving any warnings make sure you re-post that as well.
