• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Valued Contributor
    AutoCAD 2012 - Not highlighting an object before you select it.
    2148 Views, 5 Replies
    07-28-2011 07:25 PM
    Hey all.
    Anyone know how or why objects aren't being highlighted BEFORE you select them?
    In 2011 I was able to (say preview the object) highlight the object before selecting it.
    I noticed this when I have a few lines on top of each other and couldn't 'toggle' through to bring the correct line to the front.
    Also occurs when hatching by Object, object doesn't highlight.
    I am guessing (hoping :smileyindifferent:) its just a varible I can change.
    Cheers.
    Please use plain text.
    Charles_Shade
    Re: AutoCAD 2012 - Not highlighting an object before you select it.
    07-28-2011 07:59 PM in reply to: NormsAUS
    PICKFIRST
    Please mark any response as "Accept as Solution" if it answers your question.
    _____________________________________________________________
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    Valued Contributor
    07-28-2011 09:15 PM in reply to: Charles_Shade
    Cheers Charles,
    but unfortunately that's not the one I am looking for.
    When you put your curser over something the object will normally become bold.
    When I put my curser over an object a properties box appears, but the object doesn't become bold.
    Valued Contributor
    07-28-2011 09:24 PM in reply to: NormsAUS
    I did a little more research.
    OPTIONS > SELECTION (tab) > SELECTION PREVEIW (box)
    Type:Bitcode
    Saved in:Registry
    Initial value:3
    Controls the display of selection previewing.
    Objects are highlighted when the pickbox cursor rolls over them. This selection previewing indicates that the object would be selected if you clicked. The setting is stored as a bitcode using the sum of the following values:
    0
    Off
    1
    On when no commands are active
    2
    On when a command prompts for object selection
    Thanks.
    Charles_Shade
    07-29-2011 05:03 AM in reply to: NormsAUS
    Glad you found it.
    New Member
    07-27-2012 09:38 AM in reply to: NormsAUS
    Cheers NormsAUS.
    This was a problem that hit me this afternoon and I have no understanding why it all switched off. The only reason I can think of is that I loaded an arx file for a new Point Cloud plugin and since then things were a little different. I suspect it was that because it also turned off my Dynamic Input.
    Anyway, thanks again. Great help.
    ML
    surDRAFT
    www.surDRAFT.com
