• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Member
    Auto CAD license combination
    62 Views, 2 Replies
    07-01-2012 09:27 PM
    I have combined all the licenses of our company to one SN.
    but all old SN still can be used.
    is that normal?
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Auto CAD license combination
    07-02-2012 06:21 AM in reply to: sdautodesksh
    You need to contact an Autodesk reseller to discuss licensing.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    *Expert Elite*
    TravisNave
    07-02-2012 09:17 AM in reply to: sdautodesksh
    The system should eventually expire those old serial numbers and prevent them from being activated.  You should get an error stating that the license serial number is invalid.  Granted, this will not affect any previously installed and activated software using that serial number.  However, subsequent reinstalls should no longer work.  In any case, for licensing compliance, you should only use the number of licenses that you own.  If you have any questions, contact your Reseller as Dean advised.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
