• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Area within block as an attribute
    35 Views, 0 Replies
    06-22-2006 10:49 PM
    Here is the problem:
    I'm detailing many shapes made of plates. I want to create a block with attributes as follows:
    NO.
    Name
    Area
    Then, I want to export it to csv file and import to MSExcell to make part list.
    Area*thickness=volume
    volume*density=mass of each element
    Is it possible to put area of an object (i.e. polyline) as an attribute to a block?
    I know that I can put FIELD in a block with attributes with "Area" property of an object. But only in full AutoCAD 2006 not in LT
    When I check properties of an object there is Area property - Can I export it outside AutoCAD?
    Thanks for any kind of help.
    Lucas
    Please use plain text.
