• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Alternative to Wipeout?
    578 Views, 8 Replies
    09-18-2008 08:38 AM
    Wipeouts work fine for simple objects with minimal vertex points, but is there a simple way to paint a hatch on a closed object that is a solid background color and keep the border visible? (LT2007)
    Thanks in advance!
    Please use plain text.
    hwalker
    Re: Alternative to Wipeout?
    09-18-2008 08:43 AM in reply to: backinblack
    Use the SOLID hatch and change the colour to 255
    09-18-2008 09:48 AM in reply to: backinblack
    That leaves a white fill on the screen. I'd like to have a fill that is the same as the background color, non-transparent and will not plot.
    *Dean Saadallah
    09-18-2008 12:52 PM in reply to: backinblack
    Only if you forgot to set pen 255 for 0% screening (0, as in zero, nothing,
    nada). See attached, get into using your plot styles to their full
    advantage.
    Dean Saadallah
    http://LTisACAD.blogspot.com
    Add-on products for LT
    http://www.pendean.com/lt
    09-19-2008 05:49 AM in reply to: backinblack
    Yes, I've set screening to 0%. I operate in model space with a black background. All of my settings for pen 255 match your image exactly. I still have a solid white fill on my screen in model tab, but in my layout tabs the fill appears to be a 50% gray. Print Preview looks fine, and prints fine on a B&W laser printer...
    *Dean Saadallah
    09-19-2008 08:46 AM in reply to: backinblack
    Not an option, 255 will always display on screen. Try Draworder to fix the
    display without breaking the printing. Or go back to wipeouts.
    Dean Saadallah
    Active Contributor
    randomnewb
    04-09-2012 02:24 PM in reply to: backinblack
    wipeout's that allow for curved polylines would be swell. just a thought.
    pendean
    04-09-2012 06:31 PM in reply to: randomnewb
    The first reply is the answer until then.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Bob_Zurunkle
    04-11-2012 08:37 AM in reply to: pendean
    I come close to curved wipeouts by creating polygons. The tighter the details level required, the more vertices....
    If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
