AutoCAD LT
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
AEC object issue...
- Highlight
- Email to a Friend
- Report Inappropriate Content
I have aec objects in a drawing (walls, door, etc.) and every so often on part of the walls show up or the walls don't tie into each other. If I delete the wall and then select undo the walls will tie into each other. Any idea why this is happening or how to fix it? Thank you.
Re: AEC object issue...
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
LT 2013.
AutoCAD Architecture & AutoCAD MEP 2013 Object Enabler for LT is installed.
Right now it is happening with all walls in the xref drawing. I have a baseplan and the walls look good. I have a floor plan drawing with the baseplan xref in and it is happening in the floor plan.
Other times it will happen with just one wall and when I delete and undo it works fine.
Should I install the AutoCAD Architecture 2013 D-A-CH Extension Object Enabler?
- Highlight
- Email to a Friend
D-A-CH is for editing of D-A-CH Erweiterungen 2013 drawings (no, it's not misspelled): is that were your DWG file comes from?
Otherwise you found a known LT2013 bug that has no fix yet. No workaround unless you want to get rid of the AEC content in the file.
- Highlight
- Email to a Friend
I have had the drawing for a hanfull of years and I can't remember where it came from. I used to use 2007 LT and everything worked fine. I would just do save as and reuse the drawing bascially. Now in 2013 I am having the issues. Thanks for the help.
- Highlight
- Email to a Friend
You could always try using "AECTOACAD" and see if it get's any better.
AutoCad LT 2014
- Highlight
- Email to a Friend
