• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Distinguished Contributor
    AEC object issue...
    562 Views, 6 Replies
    09-28-2012 11:02 AM
    I have aec objects in a drawing (walls, door, etc.) and every so often on part of the walls show up or the walls don't tie into each other.  If I delete the wall and then select undo the walls will tie into each other.  Any idea why this is happening or how to fix it?  Thank you.
    Please use plain text.
    pendean
    Re: AEC object issue...
    09-28-2012 11:04 AM in reply to: jambruins
    LT version?
    Does it have an ARCH Object Enabler, and is it installed?
    Does this happen with all AEC files, all walls in this file, or just one wall at one location (drawn incorrectly by the originating program perhaps at this one location)?
    Dean Saadallah BLOG | Facebook | RSS Feed | LT Tips | PINS
    09-28-2012 11:09 AM in reply to: pendean
    LT 2013.
    AutoCAD Architecture & AutoCAD MEP 2013 Object Enabler for LT is installed.
    Right now it is happening with all walls in the xref drawing.  I have a baseplan and the walls look good.  I have a floor plan drawing with the baseplan xref in and it is happening in the floor plan.
    Other times it will happen with just one wall and when I delete and undo it works fine.
    Should I install the AutoCAD Architecture 2013 D-A-CH Extension Object Enabler?
    pendean
    09-28-2012 11:27 AM in reply to: jambruins
    D-A-CH is for editing of D-A-CH Erweiterungen 2013 drawings (no, it's not misspelled): is that were your DWG file comes from?
    Otherwise you found a known LT2013 bug that has no fix yet. No workaround unless you want to get rid of the AEC content in the file.
    09-28-2012 11:51 AM in reply to: pendean
    I have had the drawing for a hanfull of years and I can't remember where it came from.  I used to use 2007 LT and everything worked fine.  I would just do save as and reuse the drawing bascially.  Now in 2013 I am having the issues.  Thanks for the help.
    Valued Mentor
    AcadAdamLT
    10-01-2012 12:11 AM in reply to: jambruins
    You could always try using "AECTOACAD" and see if it get's any better.
    Signature, sincerely... //Adam
    AutoCad LT 2014
    pendean
    10-01-2012 05:35 AM in reply to: AcadAdamLT
    That would explode the "walls and doors" into AutoCAD entities only, lines and more lines: hopefully the OP does not need to keep these files intact first.
