• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD LT
    Active Member
    2009 has to recover files when opening those saved in older versions
    64 Views, 3 Replies
    10-16-2008 02:49 PM
    We have currently updated from LT 2004 to LT2009. If I try to open a file that I have not yet opened in 2009, it requires that I recover the file, rather than open it directly. There has rarely been any errors found. I have to close all other documents to recover that file. Any help?
    Please use plain text.
    Distinguished Contributor
    Re: 2009 has to recover files when opening those saved in older versions
    10-17-2008 03:22 AM in reply to: happyjj
    sounds like a problem noted in Knowledge Base:
    http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=11328222&linkID=9240817
    *Dean Saadallah
    10-17-2008 05:19 AM in reply to: happyjj
    RECOVERYMODE described in Help, explore.
    Dean Saadallah
    http://LTisACAD.blogspot.com
    10-17-2008 02:52 PM in reply to: happyjj
    Install update 1. This is supposed to help with this issue. DO NOT install update 2 - there are known crashing issues with this update that Autodesk is working on.
