I can not find my drawing in model space when hitting zoom extents or double click the wheel. I can see a speck that was a circle I drew but can not get back to my drawings. They do show up in paper space. Please advise.
Solved by pendean. Go to Solution.
Hi Alex,
This sounds like you have got another object far away from your drawing. So when you zoom extents it includes the object that is far away from your drawing.
Once you find and delete it, you should be ok with zooming to extents. Try looking for it in your model layout and make sure that all layers are visible and switched on to find it.
Hope this helps.
Martin Mitchell
Nothing attached, but you can fix this yourself: go into the viewport using VPMAX command, start LINE command, click in the middle of your drawing then while still in the LINE command 'Zoom>Extents, ensure ORTHO is turned off and click the second point for LINE command somewhere on screen.
Now obviously the other end of LINE you just drew is where your drawing is, so start ERASE and delete everywhere else. Zoom out additionally if needed.
VPMIN to get back to paperspace when you are done. Now check your handy work in Modelspace.
Just to add something that may help.
Hope this helps.
Martin Mitchell
Thank you but this still does not work. I have attached the file for you to see.
ERASE
ALL
then hold SHIFT down and window around your objects.
Offending objects deleted. Your file is fine.
Thank you for posting your solution it worked for me but I don't understand why this happened and why I had to hold shift when I made a selection. Please could you explain what is happening?
