AutoCAD LT General
New Member
s.geddes
Message 1 of 4 (200 Views)
xrefs cause lag in object selection
200 Views, 3 Replies
05-22-2012 11:27 AM
I am working on a drawings with nested xrefs and am experiencing major delays when selecting objects using crossing windows. It is as if the computer thinks I am selelecting the xref even though the curser doesn't touch any visible exref entities. Basically, I click to start the window and the curser freezes for 10 to 20 seconds. I am experiencing the same problem with other commands (intermittenly) such as move, line, and offset. The exrefs are on a separate locked layer and have been moved to the back of the drawing. Does anyone have an explanation for this or a solution?
pendean
Message 2 of 4 (196 Views)
Re: xrefs cause lag in object selection
05-22-2012 03:00 PM in reply to: s.geddes
How many Xrefs in total?
PC specs? Windows OS?
LT version?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Valued Mentor
AcadAdamLT
Message 3 of 4 (187 Views)
05-23-2012 03:58 AM in reply to: s.geddes
Are you absolutely sure it's the Xref's that are causing the lag? if not, try to unload all of them. If you don't have any more lag after that try reloading them one at a time to see if it's all xref's or just one of them. Or maybe it's just too many xref's and your computer can't handle them all.
Signature, sincerely... //Adam
AutoCad LT 2014
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
New Member
jverplanck
Message 4 of 4 (19 Views)
07-08-2014 11:46 AM in reply to: AcadAdamLT
s.geddes is not alone, I am having the same issues, at first I though it might be contextual ribbons but without the ability to turn them off I cant eliminate that as a potential cause. The same files open fine in 2014 so it shouldnt get worse in a new release.
You are not logged in.
Ask the Community
