AutoCAD LT Forum
viewport scale field not updating
3 REPLIES 3
KristinLindberg
1939 Views, 3 Replies
our field is not updating properly.
MTEXT
(point)
J
MC
(opposite corner)
[Field via Insert>Field]
[Object, clicked viewport edge; Custom scale; Use Scale Name]
Enter
The correct scale shows. However, when we change the scale of the viewport, the original inserted scale remains the same in the field. We've also used "#"=1'" and "#=1'-0"" and "1"=#'"
Suggestions much appreciated. Our average projects consist of 40 layouts. Doing this manually is a bit time consuming. This used to work, so we're baffled.
AutoCAD LT 2009, standalone commercial license, activated.
AutoCAD Mechanical 2013 SP2
AutoCAD 2013 SP2
3 REPLIES 3
pendean
in reply to: KristinLindberg
Look up FIELDEVAL system variable in LT's HELP, and ensure DEMANDLOAD variable is not set to 2.
KristinLindberg
in reply to: pendean
This is what I end up with, and have NO clue when it comes to fieldeval. also, "DEMANDLOAD" is unknown in LT.
Command: FIELDEVAL
Enter new value for FIELDEVAL <31>:
Smiley Indifferent
AutoCAD 2013 SP2
Thanks for the help. Not sure why, but today everything is back to normal.
AutoCAD 2013 SP2
”Boost
