AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
unhandled exception c0000005
5 REPLIES 5
922 Views, 5 Replies
We are using AutoCAD LT 2005
Program respond this -error unhandled exception c0000005 (access violation Reading 0x0014) at address 65873E46h-
We are running Microsoft Windows 2000 Server. All user accounts and all user files are stored on that particular server (user has no access to local disc!!!). On our workstation there are stored only system and program files.
5 REPLIES 5
http://support.autodesk.com select LT for the program from a pulldown use the search box for your error message, and variations of it and see what's posted. -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
already done that. Let me specify problem.
AutoCAD LT 2005 work properly when I log on as Administrator, but when I log on as user (no access to local disk) AutoCAD LT 2005 don't load menu. So I put menu file on server and try running AutoCAD LT 2005 program show this message "Exception in C:\Program Files\AutoCAD LT 2005\AcAssist.arx ARX Command-Unhandled Exception C0000005) Access Violation Reading 0x0014) at address 65873E46h-" and I`am still no able to load menu file.
I try then to install AutoCAD 2005 Trial and there no problems.
Is the only solution to UPGRADE from AutoCAD LT 2005 to AutoCAD 2005? Please help!
AutoCAD and LT install and behave the same, 100% identical in that manner. You might want to investigate any differences in setup you may have. There is also a networking discussion area under the AutoCAD link on this site you can post to for more setup type questions. -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
I have the EXACT same error message to the letter. I realize that it's been a year since the last post. Do you remember how you resolved this? byte_giga@hotmail.com
Having the same problem and getting that error code did it ever get a solution?
”Boost
