AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
"Ticks" at tangent points..
6 REPLIES 6
bmw1789
730 Views, 6 Replies
I am currently working on a landscape plan and I have been given a plan with by an "old timer" in our firm to plot out. He specifically wants tick marks at all tangents..is this possible to do automatically without having a lisp? I don't mind selecting the arc and manually doing it..since I have already been drawing them in one by one manually.. Please help if anyone had any ideas!!
6 REPLIES 6
pendean
in reply to: bmw1789
Create a "tick" block and INSERT it: wouldn't that be what the lisp will do?
Or do you need to use POINT objects? Just set PDMODE to a shape other than a dot.
bmw1789
That post was a while back..by using the suggested PDMODE can you make those "tick" marks parallel perpendicular with the arch which is being referenced? It would be a useful tool to have in the future
bob_mpc
No, the point marks always are aligned to the coordinate system.
You should make a dynamic block with "ALIGN" action. See the sample.
Boris
AutoCad LT 2021.1.1
bmwalker1789
in reply to: bob_mpc
Thanks for that sample.  I was able to open it in block editor change the color and just move it to my tool pallette! big help.  Now for another question.  I am interested in a macro/ diesel script that will automatically go to the options of scale and then reference and repeat the command until i press escape.
For example if i have a circle  and I want a "plant" block to be the size of the circle instead of running the scale command, selecting a point, then typing R, and then the center point again, and then the another point to scale to.  Is there a way I can select the block, type "SCR" and then immediatly pick the next two points and then it repeat it so that i can do multiple "plants at one time?
I have looked into creating my own macro but when I looked at the scale Macro String it was a diesel, and I was at a stand still.  Smiley Sad
pendean
in reply to: bmwalker1789
That's LISP if you want to type it and have the magic done for you, not a feature of LT.
If your plant block was created with a basepoint in the center, your macro would invoke the INSERT command, call the plant block, activate the CENTter osnap, wait for you to pick the circle in question, your macro would then flip to the QUAdrant (or NEArest) osnap and wait for you to pick the edge of the circle. Two clicks for you after you click to activate the menu button that houses the macro.
bob_mpc
Glad to be of help.
I fail to understand why this so complex procedure? Just tick in the Insert window the "Specify on screen" for scale and you can easily just drag with the mouse to the circle. This, of course, means that the block must be created to fit in circle with radius 1.
Or, to avoid repeatedly dealing with the insert menu, you can do it with "mulltiple -insert" (don't miss the minus). This invokes the textscreen version of "insert" and you can just hit "enter" (or right-click) at the first promt (the name of the block - it is by default the last one inserted) and again pick the center of the circle and then pick again a point on the circle. The "multiple" repeats the "-insert" until you hit ESC.
Boris
AutoCad LT 2021.1.1
”Boost
