AutoCAD LT General
*Stéphane Dumouchel
Message 1 of 2 (278 Views)
portable licence failed lt2007
278 Views, 1 Replies
05-17-2007 05:38 PM
anyone can help?
recently i exported my autocad licence from my computer at work whit
success.
When i tried to import my licence in my computer at home it failed.
There is a dilog box that said "THE LICENCE TRANSFER CODE IS NOT VALID.
CHECK THE CODE ON THE SOURCE COMPUTER, AND THEN TRY AGAIN .
ERROR CODE : 17.1.91
I tried either with transfer code and transfer file.
I check the code on the computer source, the code is correct and the
computer identification code is correct.
I did the transfer a hundred time before and it's always works . i don't
know what's happen this time.
Can i cancel the transfer of my licence on the source computer, if so how
can i do this.
thanks .
P.S. excuse my poor english
Stéphane D.
Motion canada.
drew3rdof3
Message 2 of 2 (278 Views)
Re: portable licence failed lt2007
05-17-2007 07:17 PM in reply to: *Stéphane Dumouchel
Stéphane,
This happened to me once because I copied the code wrong. After that, I copied and pasted the code into a simple text file on a flash drive to keep from making that mistake again. In your case I would copy or print a screen shot of the "Computers" tab in the Portable License Utility and compare the computer names and identification codes on both your home and work computer.
I personally think the PLU is a little over the top for us work-a-holics. I am allowed to install the PCB layout & schematic package on both computers as long as they are not running at the same time.
Good luck and,
Cheers!
Drew
You are not logged in.
Announcements
Need installation help?
Ask the Community
