AutoCAD LT Forum
portable licence failed lt2007
1 REPLY 1
471 Views, 1 Reply
anyone can help?
recently i exported my autocad licence from my computer at work whit
success.
When i tried to import my licence in my computer at home it failed.
There is a dilog box that said "THE LICENCE TRANSFER CODE IS NOT VALID.
CHECK THE CODE ON THE SOURCE COMPUTER, AND THEN TRY AGAIN .
ERROR CODE : 17.1.91
I tried either with transfer code and transfer file.
I check the code on the computer source, the code is correct and the
computer identification code is correct.
I did the transfer a hundred time before and it's always works . i don't
know what's happen this time.
Can i cancel the transfer of my licence on the source computer, if so how
can i do this.
thanks .
P.S. excuse my poor english
Stéphane D.
Motion canada.
1 REPLY 1
Stéphane,
This happened to me once because I copied the code wrong. After that, I copied and pasted the code into a simple text file on a flash drive to keep from making that mistake again. In your case I would copy or print a screen shot of the "Computers" tab in the Portable License Utility and compare the computer names and identification codes on both your home and work computer.
I personally think the PLU is a little over the top for us work-a-holics. I am allowed to install the PCB layout & schematic package on both computers as long as they are not running at the same time.
Good luck and,
Cheers!
Drew
”Boost
