AutoCAD LT General
pcw13
Message 1 of 4 (268 Views)
Accepted Solution
plotstyles .ctb
268 Views, 3 Replies
09-17-2012 08:38 AM
I have just upgraded from AC LT2009 (Windows XP)  to AC LT2012 (Windows 7)
It could not find my old plotstyle files.  So I copied both the .ctb and the .stb files to the "User data cache"\plotstyle\ folder because that is where I found the 2012 .ctb files located.  When I go to plot it still shows that the one I want to use as "missing".
How do I make those files active??
In other upgrades that is all I have had to do was to copy the files into the new location.
Please help
Distinguished Contributor
lrlandusky
Message 2 of 4 (265 Views)
Re: plotstyles .ctb
09-17-2012 09:18 AM in reply to: pcw13
Check your plotter file location in AutoCAD:
1. Click the "A" menu in the upper left and then click the options button down on the right.
2. Go to the Files tab, and click the plus sign next to Printer Support File Path.
3. Check the location of the Plot Style Table Search Path.
I changed my search folder to a location on our server so we can share the ctb files.  You probably need to either specify a folder you want to use for the files or change folder to the place where you copied the files.
Hope this helps,
Lance
*Expert Elite*
pendean
Message 3 of 4 (252 Views)
Re: plotstyles .ctb
09-17-2012 11:43 AM in reply to: pcw13
In LT, old or new, start STYLESMANAGER command (type it) and the folder your system is set to look for plot style tables comes up. Copy the ones you want to/from there.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
pcw13
Message 4 of 4 (225 Views)
Re: plotstyles .ctb
09-19-2012 07:36 AM in reply to: lrlandusky
Lance,
Thank you very much your exact instructions they were perfect.  There was another "plotstyles" folder that I had placed my files in.  Thank you for telling me how to find the correct path name!
pcw13
You are not logged in.
Announcements
Need installation help?
Ask the Community
