I try to add the dwg to pdf.pc3 file to my AutoCAD LT 2014 (german)
When I click on manage plotter a File Explorer Windows pops up instead of the plotter manager.
Any clue what is wrong here?
Andy
Berlin, Germany
That is working as designed. It opens Windows Explorer to your configured "Printer Configuration Search Path"
In that location there should be a shortcut to the "Add-A-Plotter Wizard".
If not, you can manually run this program. It's named addplwiz.exe and found in the AutoCAD program directory (typically C:\Program Files\Autodesk\AutoCAD 20xx)
