I'm trying to find a setting which allows me to produce pdf copies of AC LT 2014 layouts that do not require rotation to view them in Adobe.
I've searched all through the pdf settings and still I have to rotate the pdf counterclockwise to view it in its correct orientation.
There's a setting which works for MS Office documents in the pdf options section but when this is applied in ACAD it doesn't work and I still have to rotate the view.
Any clues?
Cheers,
Jon
Solved by pendean. Go to Solution.
If you are using the Adobe PDF driver that comes with AutoCAD try paper size "Ledger".
Have you tried using PUBLISH.
That has 4 settings you can use
Plotter named in page setup
Dwf
Dwfx
And the PDF is always the correct orientation.
Howard Walker
I trying to plot a pdf onto a 24"x12" format and the plot is not centering in the printable area.
How to?
