AutoCAD LT General
Product Support
MichaelBussiere2
Message 11 of 12 (244 Views)
Re: paste issues again!!
11-20-2012 07:25 AM in reply to: EL-Designer
Thank you to everyone engaging in assisting in this post.  One suggestion moving forward would be to perform a total clean up procedure on a test copy of this affected file using the sequence outlined in the link below.  This will then strip out all potential problems and create a new, fresh, cleaned up file for use.  This also works for many other scenarios of corrupted or lagging files.
File clean up: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18809891&linkID=9240617
Michael Bussiere II
Support Specialist
Product Support
New Member
jorayh73
Message 12 of 12 (105 Views)
11-11-2013 07:07 AM in reply to: MichaelBussiere2
I'm having this same problem.....I have even cut the file into 3 files and it just stops allowing me to paste. I have deleted and reinstalled Autocad LT 2013 as per support. This didn't help either. I also followed this last step as well and it still does the same thing. It will paste once or twice then stop and like the other guy said if it does paste something I've never seen pops up. I've never seen anything like this and it's hard to get a project out with all of this.
You are not logged in.
Ask the Community
