i have a drawing that has about 450 identical instances of a block. The block has visiblity options to show different things. I dont want to edit the block as there isnt anything wrong with it.
What i need to is update the blocks all together to change visibilities. Can this be done globally or is it a case of patience?
cheers
Nigel
Hi, if you can change the visibility thru the properties window you can use the select similar comand to change them all at once.
Assuming all your blocks are in modelspace
Go into modelspace
Right Click
Choose 'Quick Select...'
Object type at the moment is 'Multiple'
Change that to 'Block Reference'
Scroll down the list below block reference until you find the item 'Name'
Now below you have two more items
One says 'Operator' and one says 'Value'
Make sure Operator says 'Equals'
and value is the name of your block
Then click ok. This will select all instances of your block in modelspace
Now right click and choose properties
At the bottom of the properties box there is a section with the heading 'Custom' and in there is an item called 'Visibility' Change that to what you want and all your blocks will change at once.
The above sounds long winded, but it is very quick
Howard Walker
Anytime you type out the steps to do something it seems five times longer than it actually is.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
