AutoCAD LT Forum
modifying existing drawing files
2 REPLIES 2
289 Views, 2 Replies
How do you create a block within a layer and set scale to same as other saved symbol blocks
2 REPLIES 2
drjohn
Always draw one to one if it is a drawing entity (gear, steel shape ... etc).  If it is just a symbol (revision flag, whatever) make it the size you want it to be printed.  If you dim in MS you may want to make it annotative.
For our application, I personally only draw parts and assemblies in MS (@ 1:1) and dim in PS, therefore my symbols are all created the size I want at print time.
DJ
Charles_Shade
OOTB Blocks are all ready drawn at 1:1
Therefore your new blocks should be drawn 1:1 or at the same size as the OOTB Blocks as DJ stated.
(of course it is hard to draw a 65' tractor trailer on a 20" monitor at 1:1. A lot of panning around. Smiley Wink)
”Boost
