AutoCAD LT Forum
mleader collecting on top
4 REPLIES 4
622 Views, 4 Replies
MLEADERCOLLECT is putting the tags on top rather than on the bottom of the tag with the leader.  The only control as far as I can tell is Vertical.  At my other office on 2010 additional tags attach to the bottom of the leader tag.
4 REPLIES 4
pendean
Same exact drawing, different behavior based on which location edited it? Are both versions "2010"? 2012 and higher here does what your image shows.
drjohn
If you watch the command line there will be options.  VERTICAL HORIZONTAL and WRAP.
VERTICAL and HORIZONTAL are self-explanatory.  WRAP,  on the other hand is not.
If you select VERTICAL it will respond as your drawing shows.  If you select WRAP it will place the leader at the top bubble and place the other bubbles below.
The selection you make will stick and be the same the next time you collect leaders.
Also worth noting, the selection sequence is important also.
in reply to: pendean
Not the same drawing but this is happening in 2013 LT and the other office is in full 2010.
So that's the standard now?  I liked the way it was drawn in 2010.
This by the way is the icon they're still using in 2013.
in reply to: drjohn
Wrap works!  Thank you.
Important note: set the distance to 0
”Boost
