Can anyone please help me in creating lisp for selecting text in enclosed entity and copy it to excel.
I have tried with below lisp but its not working out please help.
your help is highly appreciated,
(defun C:xport ( / ss elist at cmde cen rad p1i)
(setq cmde (getvar "cmdecho"))
(setvar "cmdecho" 0)
(setq ss 0 elist (entget (car (ssget "X" ' (list(( 0 . "POLYLINE" ) ( 8 . "avn" ))))))))
(setvar "OSMODE" (boole 7 (getvar "OSMODE") 16384))
(if (zerop (getvar "CMDACTIVE")) (command "_select"))
(command "_wp") ; or _CP
(if (= (cdr(assoc 0 elist)) "CIRCLE")
(progn
(setq cen (cdr (assoc 10 elist))
rad (cdr (assoc 40 elist))
(repeat 90 ; 360/4 0.06981317=4*pi/180
(setq p1 (polar cen (* ss 0.06981317) rad) ss (1+ ss))
; (command "_POINT" (trans p1 0 1))
(command (trans p1 0 1))
)); else
(repeat (length elist)
(setq at (nth ss elist) ss (1+ ss))
; (if (= (car at) 10) (command (cdr at)))
(if (= (car at) 10) (command (trans (cdr at) 0 1)))
);if CIRCLE
(command "")
(setvar "OSMODE" (boole 2 (getvar "OSMODE") 16384))
(setvar "cmdecho" cmde)
(progn
(setq fname (getfiled "Save Text File As:" "" "csv" 1))
(setq fn (open fname "w"))
(setq i -1)
(repeat (sslength ss)
(setq i (1+ i))
(setq en (ssname ss i)
elist (entget en)
txt (cdr (assoc 1 elist)))
(write-line txt fn))
(close fn)))
(princ (strcat "\n* Text file " fname " \n has been created *"))
(setvar "cmdecho" 1)
(setq fn fname)
(startapp (strcat "Notepad " (chr 34) fn (chr 34)))
(princ))
Thanks in advance.
Solved by davedt31. Go to Solution.
