OK, this is a new function for me. I have several .dwg files from an architect each with several hundred layers. I set up a Layer State in one drawing with just the layers I need. I want to use the same Layer State in the other drawings. I opened the Layer States Manager, selected my layer state, and clicked export, selected a location and closed the widow.
I double checked in the file manger in Windows 7 that the .las file was where I had exported it. Then I opened the next .dwg, opened Layer States Manager, navigated to the file location and the .las file does not show up.
When I go back to the original drawing and click Import, the .las file is not visible either, but it is if I click Export.
Any ideas? I am working on drawings on my hard drive not a network, and saving the .las file to my hard drive.
Solved by katie1994. Go to Solution.
