When i click on view and then toolbars and when i try to get my layer properties a message appears about Unhandled exception has occured. If you click Continue, the application will ignore this error and attempt to continue. But it is not continuing. It says to see the end of this message for details on invoking JIT debugging instead of this dialog box
A Search of this Forum has suggested trying a Repair Install of LT first to see if that clears this up.
It also has been suggested that this may be an internet connection issue but in your case you do not seem to be looking to go online with your issue.
A couple of suggestion revolved around Scale Lists as well.
A complete removal in reinstall would be the last option if the Repair does not work.
What is your LT version?
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
