AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
inserting jpeg into autocad?
4 REPLIES 4
hippogriff
7012 Views, 4 Replies
Good day,
I was wondering if I could insert a jpeg file into autocad?
Instead of creating a logo for a titleblock in autocad, I thought that I could create the logo in photoshop and then insert it into autocad. Is this possible?
Thanks!
4 REPLIES 4
in reply to: hippogriff
Only if you get somene with full Autocad to do the initial attaching. However I personally avoid using image logo's as they tend to slow opening of the file. Plus the file size is substantially bigger than using acad entities.
Copy/Paste between both open applications, then post back when you have
plotting quality issues and we can try a few other things before you decide
to go back to drawing it all in cad 🙂
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
cyashowitz
I created a template file and inserted a jpeg file of the companys logo. Haven't had any problems. I just wish they had the radster image in LT becasue I work with wood products for moulding and the curves are basically trial by fire. So far haven't had any major problems but it adds to the time taken to do the arc's by guessing or by using points of an edge. They should have included it with the LT version. It's a must.
Could try a bitmap to vector utility, such as comes with Corel Draw. I use this all the time when base info drawings come to me on paper instead of ACAD file. I scan the drawing, use the bitmap/vector conversion, save to dwf, and bring to ACAD to polish. Then I can trace the image quickly.
I think a similar approach may work for you.
Ron
”Boost
