AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
inserting image into autocad
2 REPLIES 2
249 Views, 2 Replies
Whats the difference btwn attatching an image as a xref and copy pasting? Also is the only difference the type of path i choose for my image have to do with tracking the image? Either way if i send it to someone i would need to send it as a etransmit file?
thanx
2 REPLIES 2
rkmcswain
If you paste in an image and the resulting object is an OLE object, then the image is embedded in the DWG file.
The downside to that is poor quality, printing issues, and other things.
Generally there are less problems when you attach an image and send it along for the ride.
R.K. McSwain     | CADpanacea | on twitter
pendean
... and always use ETRANSMIT command to send files: it remembers more often that you what all needs to be included for the recipient of your file(s).
”Boost
