AutoCAD LT General
Distinguished Contributor
Message 1 of 5 (295 Views)
Accepted Solution
-insert using Blockname
295 Views, 4 Replies
10-12-2012 06:25 AM
Has anyone used the command -insert -blockname = filename successfully?
What I have tried is:
^C^C_-insert;"Insulation - 25-50mm"="K:/All Staff Personal Folders/Personal_Charles Edwards/Autocad/Blocks/Detail Blocks/Insulation - 25-50mm.dwg";
Trying to run this I get:
Command: _-insert
Enter block name or [?]: Blockname="K:/All
""K:/All.dwg": Invalid file name.
*Invalid*
Any thoughts on where I'm going wrong on syntax?
*Expert Elite*
Charles_Shade
Message 2 of 5 (279 Views)
Re: -insert using Blockname
10-12-2012 09:41 AM in reply to: ChuckEdwards
Macro's are nothing more than what you can type at the Command Line.
When you type your path at the Command Line where does it fail? (hint the = sign. :smileywink:)
This is the same place it is failing in the Macro.
Here's a long example:
^C^C-la;_make;BP; -insert C:/Blocks/Dynamic/Dyn_Pl-bp.dwg \;;\_draworder;last;;B
(Excuse the lack of semicolons Dean)
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
*Expert Elite*
pendean
Message 3 of 5 (272 Views)
10-12-2012 12:26 PM in reply to: Charles_Shade
tsk! tsk!
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
*Expert Elite*
pendean
Message 4 of 5 (270 Views)
10-12-2012 12:35 PM in reply to: ChuckEdwards
Since you are replacing blocks with the same exact name, why not follow the other rule about block replacement? From HELP:
"Updating a Block Definition: If you make changes to a block file that is inserted in your drawing and you want to change the existing block definition without creating a new block insertion, enter the following at the Specify Insertion Point prompt (following the Enter Block Name prompt):
block name=
If you enter = after the block name, the following prompt is displayed:
Block "current" already exists. Redefine it? [Yes/No] <No>: Enter y, enter n, or press Enter
If you choose to redefine the block, the existing block definition is replaced with the new block definition. The drawing is regenerated, and the new definition is applied to all existing insertions of the block definition. Press Esc when prompted for the insertion point if you do not want to insert a new block into the drawing."
Just ensure that path that points to the new block location is in LT's search path (OPTIONS' FILES tab, top entry): if it's not there now, you might have to restart LT after you put it there.
Message 5 of 5 (244 Views)
10-14-2012 02:12 AM in reply to: pendean
Thanks Dean,
Now makes sense where I'm going wrong, taking the blockname=filename to be a single statement and not with prompts needing to be dealt with midway.
Charles.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
