I have a large AutoCAD LT file that, starting today, crashes whenever I select a particular hatch shape.
I've worked in this file before, it's a client file that changes and updates over time so it's an important file and it would be impossible to recreate.
I can select other hatches on the same layer, even the hatch right next to this hatch, with no problem but the moment I click on this hatch - dead in the water. I get the little spinning circle and I wait and I wait, and finally I force close the program. I can copy the geometry including the hatch by doing a region select and after repositioning the geometry I can select the new hatch as normal. But I can't select the original, delete it, or do anything to it without crashing.
Any thoughts would be appreciated
Thanks for the quick reply.
Yes, I audited and AutoCAD found and fixed 2 errors but the problem persists. I can still work in the file. I put a big red circle around the offending area after I copied the geometry to a new location but it bothers me to have this corrupted part of a drawing staring at me.
You could try doing a write block of the entire dwg and see if it's fixed in the new file.
Hello
You are speaking about large DWG, so ...
Of course, you have audited (YES) and purged the DWG ?
Q1) Which size your DWG File ?
Q2) Which ACAD LT are running ?
Q3) 32 or 64 bits ? on which Windows ?
Q4) How much Ram in Gb on your PC ?
Bye, Pat
Patrice BRAUD
Thanks for all the replies.
It was an informative thread for me.
I learned several things - about thawing layers, selecting outlines and using audit.
As it turned out - I opened the file on my home computer and successfully selected the hatch and deleted it. Maybe I'll never know.
Thanks again.
