I installed ACAD LT 2011 in my new HP Win7 computer, and the font in the Layer Properties Manager box is so large that it is unreadable. I have attached a file showing a 'print screen'. I need directions on how to put the text back to normal size. I had no problems with this program in my old Dell computer.
Solved by pendean. Go to Solution.
Increase the width of the linetype column?
Otherwise change the name of the font to something shorter.
By chance, when you started using your 'new' Win7 Computer, did the desktop fonts look too small and you decided to increase their size in Windows so that you could read them better? Or someone else do that for you?
And that method was...?
Probably the cause, since AutoCAD alone, by itself, it is difficult to achieve the result you shared IMHO.
