AutoCAD LT General
Active Member
AJAMP
Message 1 of 6 (920 Views)
dwg compare plug-in
920 Views, 5 Replies
11-15-2012 09:51 AM
I was told that I should download and install DWG compage plug-in to compare 2 dwg files.  I have downloaded the file and installed it (at least I got the "successfully installed" message) but when I open AutoCAD LT 2013 it does not show up on the plug-ins tab and using the dwgcompare command returns an "unknown command" response.  Am I missing something in the initialization of this plug-in?
Mark
Charles_Shade
Message 2 of 6 (908 Views)
Re: dwg compare plug-in
11-15-2012 12:07 PM in reply to: AJAMP
What is the link to this plug-in?
AutoCAD LT is not TurboCAD Pro.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
DarrenP
Message 3 of 6 (904 Views)
11-15-2012 12:16 PM in reply to: Charles_Shade
i am assuming its the one from the exchange app store which doesn't work with lt only with full blown autocad and  the verticals
http://apps.exchange.autodesk.com/ACD/Detail/Index?id=appstore.exchange.autodesk.com%3adwgcompare%3a...
Active Member
AJAMP
Message 4 of 6 (898 Views)
11-15-2012 12:38 PM in reply to: DarrenP
This is the link I was given.
http://apps.exchange.autodesk.com/ACD/2013/en/Detail/Index?id=appstore.exchange.autodesk.com%3adwgco...
We are using AutoCAD LT 2013 and I need to compare and combine edits that were made to the same file by 2 different editors 'simultaneously'.
Mark
Charles_Shade
Message 5 of 6 (894 Views)
11-15-2012 01:02 PM in reply to: AJAMP
On the right side there is a matrix that shows what this App is compatible with.
AutoCAD LT is not mentioned here.
pendean
Message 6 of 6 (879 Views)
11-16-2012 04:43 AM in reply to: AJAMP
No such tool exists for LT: sorry.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
You are not logged in.
Ask the Community
