AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
dwf to dwg
4 REPLIES 4
3897 Views, 4 Replies
dwf to dwg
Kindly i need an urgent answer.im a quanttiy surveyor and i have a very big project drawn as DWF.i need to convert them into dwg. i already did my research and i found one that he will convert them to dwg but it will be replace into layout not model so i canot take  my qtties and they re accurate
Please all i need is how to quantiifed a DWF file , or if therse is a software to convert my dwf into dwg
HELP
4 REPLIES 4
pendean
Try a google search for the answer: AutoCAD/LT does not do the conversion.
AutoCAD/LT allow you to reference a DWF as an attachment if that will work for you, or you can download Autodesk's free DESIGN REVIEW program to read and measure DWF files.
in reply to: pendean
Well, i  download a file call : Easy cad conveter he is good but he replaced the Dwg in a layout not on model and if u know we canot work on layout.so all i need is if u know how to quantitfied a porject trough dwf by  taking areas,dimensions , perimeter.... in a quick way and correct  qttes ,...any advice ??
Many thanks
Samar .
pendean
DWFs are electronic paper file formats: everything will be the size of a paper/sheet/layout. Contact the manufacturere of your downloaded product for support or questions.
Or explode using CHSPACE command in AutoCAD: but you'd better check sizes of known items to confirm it is accurately scaled.
LoisSMatthews
You should try Autodwg product.
They have DWF TO DWG converter, both standalone and plug-in, I use their pro version and found it useful. The plug-in not seems to work well on latest Autocad.
You can check out their site here:
www.autodwg.com
”Boost
