Software: ACAD LT 2010. Recently I upgraded to a new computer and Windows 7, from Win XP. Now ACAD is lagging and dragging. Also, sometime it takes forever to open a file.
Here are my new computer specs.
Dell Precision T3600,MT,425W
I tried the solution below with no luck.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14898223&linkID=9240617
I have also installed a new graphics card provided by dell with no luck.
Then as you note, it has nothing to do with your slowdown.
Try setting the customer involement program in the communication center to "Do Not Participate" if it is not already. Also, turn off COMMCTR and see if that helps.
By chance, have you recently (or normally) access a thumbdrive or mobile drive with AutoCAD?
COMMCTR is not a valid command (if thats what you are implying). I selected 'do not participate' with no luck.
No, that was my abbreviation for Communications Center.
Do this test: OPEN, SAVE and CLOSE about 12-15 DWG files on your PC (don't skip a step) and see if you can get AutoCAD to 'forget' about that USB you accessed recently. Then see if your performance goes up.
BTW, disconnect the device from your USB ports as good measure.
If all this fails, I'm afraid I've run out of ideas. You might consider paying for support to get further or wait for other ideas to try from other users:
Safety Net / Per Incident Autodesk support (not free):
http://usa.autodesk.com/support-offerings/per-incident/
Contact a Reseller for support (not free):
http://www.autodesk.com/reseller
Since you have nothing to lose, you might consider a proper uninstall and reinstall (latter while in Diag mode in Windows): Autodesk recommended uninstall/reinstall procedures are as follows
Uninstall: http://usa.autodesk.com/getdoc/id=TS45252
Reinstall (for XP/Vista users): http://usa.autodesk.com/getdoc/id=TS75218
Ensure the user installing/uninstalling and using the product have enough rights to do so (install and reinstall as local administrator):
Unable to run AutoCAD® as a restricted user http://usa.autodesk.com/getdoc/id=TS1055299
More complete .NET fix if needed:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
