OR use PASTEBLOCK command, or replace the general paste with Pasteblock
command by adding the CTRL-V function in your menu file under the
**ACCELERATORS section.
Try this: quit LT, find and backup your ACLT.MNS file (found in the Support
sub-folder of LT's program folder). Use Windows Notepad and open the
ACLT.MNS file, scroll down to the **ACCELERATORS section and add the
following line:
[CONTROL+"V"]^C^C_pasteblock
Now restart LT and enjoy.
Dean Saadallah
http://www.pendean.com
LT Express utilities
http://www.pendean.com/ltexpress
Expanded Links Pages
http://www.pendean.com/lt/links.htm
"Simon Bruce" wrote in message
news:231440D698391D257B580D7B3A1B70A7@in.WebX.maYIadrTaRb...
> Once you have copied to clipboard, instead of using the paste command or
tool button, try using your right mouse button. You'll find there are
several options for pasting the copied items, one of which is Paste as
Block.
> Regards
> Simon
> www.drcauto.com
> "BruceR" wrote in message
news:f12db27.-1@WebX.maYIadrTaRb...
> Under LT 97 when I copied something to the clipboard and then pasted it
into the drawing, it came in as a block (which I could reposition and then
explode when I got it where I wanted it). Is there a setting I can modify to
make that happen in LT2002, or am I stuck W-blocking and renaming the new
block every time I want to do this now?
