AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
change decimal separator from dot to comma
3 REPLIES 3
3524 Views, 3 Replies
Does anybody know how to change decimal separator from "." (dot) to "," (comma)? I know how to do this in dimension text, but I'm using table with bill of materials, and I want to use sum of weights of particular parts, with precision of two places after separator. How to change the character of separator to comma?
3 REPLIES 3
I think that's a windows control panel/international setting
I also have this problem. Unfortunately, doesn't work. Normally in windows, I've set the comma as the decimal separator.
I had trying to fix this issue, but .... You now :).
Now You can check this https://github.com/stefangelov/DecimalSymbolFixer.
This is custom tool and for me works good.
Please feedback if You try to use it.
Thank You!
Good luck!
”Boost
