AutoCAD LT Forum
cannoscale keeps crashing my AutoCAD LT 2008
1 REPLY 1
407 Views, 1 Reply
Does anyone have any advice on how to address this or avoid it?
I have a drawing that keeps crashing my AutoCAD LT 2008 when I try to change the annotative scale through the "drop down" list on the lower right hand side of the screen. Now here is the thing, when I finnally go into windows control panel to shut the thing down (LT just freezes) it takes quite a while to get a response then, Windows generates a Microsoft Error, but it is appears that it is cannoscale that is causing this hang up.
I did reset the annoscales to get rid of the excess "xref" scales prior to this happening. Also, when I reset it....three "xref" type scales remained.
Any insight would be appreciated.
Thanks!
1 REPLY 1
Restart your PC.
RECOVER command, start with the Xrefs first, then the top file.
Purge scalelists in all files individually, starting with Xrefs.
Turn off "maintain Visual Fidelity" in Options>open tab in LT: yes, this may
crash your session. Don't forget to tap that Apply button.
Dean Saadallah
http://LTisACAD.blogspot.com
”Boost
