AutoCAD LT Forum
binding xref crashes drawing
2 REPLIES 2
cvinz
434 Views, 2 Replies
when I attempt to bind an xref, a prompt asks me if I really want to do this. If I say (N), it just keeps asking me over and over. If I say (Y), the drawing freezes up and crashes. This also randomly happens with simple commands like stretch, erase, move, etc., except that I can escape out of those commands, although then I'm stuck with the line as it is.
2 REPLIES 2
in reply to: cvinz
LT version?
AUDIT or RECOVER the file you want to bring in and file you are in, SAVE
then try another bind perhaps.
Dean Saadallah
http://LTisACAD.blogspot.com
cvinz
in reply to: cvinz
Thanks. I'm running AutoCAD 2008 LT. I did AUDIT, and was eventually able to bind, which took 5-10 minutes, so it may have been I was too impatient earlier when the screen froze up. Still having the issues with stretch/move/erase commands with lines on certain layers.
Probably should be a different thread..
”Boost
