AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
bibliothèque de textures facade, (pierres, briques...) en 2D et en dwg
5 REPLIES 5
2268 Views, 5 Replies
Bonjour,
Je cherche une bibliothèque de textures pour facade en 2 D (pierres, briques...)
Merci de m'indiquer comment faire? Pour l'instant je dessine à la main au rotring.
5 REPLIES 5
Charles_Shade
Hatches are used in AutoCAD LT to mimic the finishes that you are looking for.
Google can be a good place to start for Hatch patterns that meet your needs.
Also these patterns need to be installed in AutoCAD so that you can use them.
What is your version of LT?
in reply to: Charles_Shade
autocad lt 2011
Charles_Shade
If you find a Hatch you like you can add it to the end of the ACADLTISO.PAT (I am assuming Metric) file or to a File that is in the LT Search path.
Find something you like and let us know if you need help loading it.
I actually do not understand acadltiso.pat my computer either when I
search??
What a fichier.PAT? What relationship with autocad light?
Why my computer bug with "hatchings"?
It's complicated everything hither! I'm much faster to draw by hand with
autocad.
Regards
Charles_Shade
acadiso.pat is the name of the Hatch Pattern File found under the Support folder in English versions of AutoCAD LT.
This is one place that you can place a Hatch pattern file that you like that can be used in LT.
Hatch Pattern files can also be placed in the Support Folder or any Folder that is on the AutoCAD Search path.
Let's start over.
Do you have or have you foind a Hatch Pattern that you like?
Google Translate:
acadiso.pat est le nom du fichier de signatures Hatch trouvé dans le dossier Support en versions anglaise d'AutoCAD LT.
C'est un endroit que vous pouvez placer un fichier de hachures que vous aimez qui peut être utilisé en LT.
Fichiers de motifs de hachures peuvent aussi être placés dans le dossier Support ou tout dossier qui se trouve sur le chemin de recherche d'AutoCAD.
Disons recommencer.
Avez-vous ou avez-vous foind un motif Hatch que vous aimez?
”Boost
