Drawing property lines on a plan and it should be a center 2 dashed line. The dashes are very large. I checked the linescale and it is set to 12 and the viewres is set higher. It seems there is a setting off.
Solved by Bob_Zurunkle. Go to Solution.
What is CELTSCALE set to?
The scale of 12 sounds like something being done to relate a civil drawing unit to architectural feet and inches, yesno?
