AutoCAD LT General
New Member
ron.white
Message 1 of 2 (197 Views)
angle option in LT2013 array command--
197 Views, 1 Replies
10-08-2012 06:25 AM
If you miss the angle option in the array comand in LT2013--tech support sent me this info--
"The angle options is removed from command line
option. However, after creation please hover the bottom right grip and select
Axis Angle and specify the angle by picking a point. If you want to enter angle
value please turn off the dynamic input and enter the angle value in the
command line. "
pendean
Message 2 of 2 (178 Views)
Re: angle option in LT2013 array command--
10-08-2012 09:10 AM in reply to: ron.white
Thanks for sharing. If you get a chance, tag your own post as the solution here so others can find it.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
You are not logged in.
Ask the Community
